TwinTurbo.NET: Nissan 300ZX forum - Should I worry? How serious is the high temp problem (more)
Subject Should I worry? How serious is the high temp problem (more)
Posted by kcmichaelm on May 30, 2003 at 12:34 PM
  This message has been viewed 60 times.
In Reply To I had mine set at 15psi for a very long time. And even then> posted by Professor X on May 30, 2003 at 11:17 AM
Message And I never replaced the turbos on my old one. I looked through the tech section but couldn't find the answer (dumb question coming) what are the stock turbos and how do T28's compare? I used to run my stocks around 16-17 max and didn't really have any problems, I used an EVC III. If you have 555 injectors couldn't the T28's run 18-19 without issue? Please advise and thanks...
:it still seemed like I had a lot of power without too much lag. But then again, my modified automatic tranny had a lot to do with it. Since I recently had the engine rebuilt, I plan on boosting it up to 17psi. I think the limit is around 20psi before you pop something. T-28's fail horribly when it comes to high temps.
:Eventually, I'll be switching over to a TD05 or TD06 setup in a year or so.
:Hope that answers your question
